clutch not workin
Old Jun 3, 2007 | 03:00 PM
94Jdmh22accord
Default clutch not workin
I recently had a problem with my clutch in a drive thru. It went down completely to the floor meaning theres no hydrolics so i got a mechanic to look at it and the slave cylinder was leaking bad. We got a newslave cylinderput in and bled it and all that but theres still no resitance and it dosent work. Any help would be great.
Thank You
Andy
Old Jun 3, 2007 | 04:15 PM
Chiovnidca's Avatar
Default RE: clutch not workin
Put a clutch master cylinder on it.
Old Jun 3, 2007 | 09:51 PM
94Jdmh22accord
is it forshor tho that the master cylinder is the problem. or could it be somethin else?
Old Jun 3, 2007 | 10:24 PM
hondadude's Avatar
Go dash diving and look at the rear of the clutch master where the pedal rod goes into it. If there is brake fluid there replace the turkey.
That system is a real pain to bleed out the air, I use a big syringe from the vet supply store[$1.25] and shove the fluid from the slave bleed screw back to the master.
Old Jun 3, 2007 | 11:18 PM
deserthonda's Avatar
look at the clutch reservoir if it is still has fluid in it, than most likely you did not bleed the system properly,, but i wouls also do as Chio and the Dude suggested , chk to make sure clutch master is not leaking , they go bad more often than the slave cylinders also, chk all the lines and hose to slave cylinder for sign of leakage ..
there is a write up on the DIY section on how to replace clutch master ( if needed ) and bleed system
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
wtony
May 24, 2008 07:47 PM
nafango2
Dec 14, 2007 11:52 PM
tamb
Jul 21, 2006 01:05 AM
