1994 Honda Accord White Transmission Fluid
Old Apr 22, 2012 | 09:28 PM
jerzeykidd's Avatar
Default 1994 Honda Accord White Transmission Fluid
My gears have been slipping and my transmission fluid is white and milky. I recently had the radiator and head gasket replaced due to another incident. The mechanic i let fix my car said that he could not clean all of the white milky stuff out in his garage. Could that be the cause of it slipping or do I have a leak somewhere else causing it?
Thanks
Old Apr 22, 2012 | 09:44 PM
Tyler Joyce's Avatar
Sounds like water or something is getting into that fluid.
Old Apr 22, 2012 | 09:51 PM
jerzeykidd's Avatar
So it shouldn't be a big problem to fix? The gears are slipping and taking forever to shift. I planned on getting my transmission fluid drained and refilled tomorrow. Would that do the trick?
Old Apr 22, 2012 | 10:18 PM
So, I am assuming this is an automatic? Your transmission had lines which ran into the oil cooler inside the radiator. The oil cooler inside the old radiator probably had holes or cracks to allow coolant and motor oil (if motor oil got mixed into the radiator coolant first) into the transmission.
You probably have to get 3 drain and fills to try to get most of the old fluid out and hope that takes care of the transmission problem. One drain and fill only gets out about 1/3 of the fluid. Honda has a certain procedure to drain and fill, run the car through gears, etc. and repeat.
Old Apr 22, 2012 | 10:43 PM
jerzeykidd's Avatar
Thanks a lot, that helped me out a ton. It's good to hear that will most likely solve my problem. Other than the fluid, what else could possibly be wrong? Could it be the clutch or throttle linkage?
Old Apr 22, 2012 | 10:48 PM
It may solve the problem only if it was due to the contaminated transmission fluid causing the slippage, etc.
Old Apr 22, 2012 | 10:54 PM
jerzeykidd's Avatar
I mean, the incident happened back in March that caused all of this to happen. i'm hoping the flushing of the fluids will work. nothing under the car is leaking if that may help. the radiator was brand new when i replaced it.
Old Apr 22, 2012 | 11:00 PM
For the transmission fluid drain and fill, only allow them to do the 3X drain and fill or an alternative method of draining through the transmission lines going to the radiator to try to get most of the old fluid out.
DO NOT let them do a machine power flush, Honda does not recommend it and it may damage your transmission (you may not notice the damage until it is driven a little more).
Old Apr 22, 2012 | 11:05 PM
jerzeykidd's Avatar
Alright, will do. Thanks! I will keep that in mind.
What else could be the problem if that does not work?
Old Apr 24, 2012 | 04:51 PM
jerzeykidd's Avatar
i took it to a transmission specialist and e said the radiator was fine as well as the transmission. he said i had a lot of water in my transmission from the previous incident, i was told to get the fluids drained and filled twice which i did, and now i see just a little but of whiteilky fluids. what should i do? the car slips a little still
