1995 Honda Accord 2.7L Head Gasket test
Old Sep 24, 2023 | 03:23 PM
btartus's Avatar
Default 1995 Honda Accord 2.7L Head Gasket test
car is blowing some white smoke again. what is the best way to test so see if it is the head gasket. will take it to my main mechanic who just did the timing belt to do the test and potential repair. any other tests recommended?
my coolant level is perfect. can see the coolant when taking the cap off.
thanks!
bt
Old Sep 24, 2023 | 06:16 PM
White smoke from the exhaust is water. The source can either be coolant from a cylinder head/head gasket leak or water vapor condensing from burning gasoline.
Leakdown test is probably the next step. Alternatively, you can pressure up the radiator and look into each cylinder to see if you have coolant entering the cylinder.
Old Sep 24, 2023 | 06:19 PM
btartus's Avatar
thank you!! I will be talking to the mechanic about it in the next day or 2 and will mention exactly what you say. My neighbor, and old school car guy thinks its my valve seals. he was curious to know if the seals can be replaced without opening the head.
Old Sep 24, 2023 | 07:31 PM
shipo's Avatar
We already covered this in a different thread, if your car is blowing white smoke, there is no way said smoke is due to worn valve seals; anybody who suggests otherwise doesn't know what they're talking about. As I mentioned in the other thread, and as @PAhonda mentioned above, have a leakdown test performed; if you do any work on the engine before a proper diagnosis, it will be roughly akin to throwing mud on the wall hoping something sticks. Said another way, throwing money at a problem is the absolute most expensive way of finding and fixing an issue.
Old Sep 24, 2023 | 08:01 PM
btartus's Avatar
I will not do anything without testing. I will have a leakdown test performed for sure. thank you for your advice!
Old Sep 24, 2023 | 08:11 PM
btartus's Avatar
also, trust me when I say, I come to this forum for advice as I know you and PAhonda and other here are Honda experts and trust the information you provide to me and others 100%. I do not take any of the information here with a grain of salt, quite the opposite, so again, thank you very much!
best regards,
bt
Old Sep 24, 2023 | 08:20 PM
btartus's Avatar
my 1995 Honda Accord LX 2.7l. I bought it with 73,000 miles 1 owner for 5k many years ago. the car has never let me down. my favorite car ive owned so far and love driving it. the original color is Pearl green.
Old Oct 23, 2023 | 02:56 PM
btartus's Avatar
ok, so my mechanic says he does not have access to the equipment for a leakdown test. He said the OTC 5609 Cylinder Leakage Tester Kit is what I need. is this correct? is there a test kit or brand that is recommended without breaking the bank?
Old Oct 23, 2023 | 04:00 PM
shipo's Avatar
I would look for a different shop which has the equipment; different shops shouldn't be too difficult to find.
Old Oct 23, 2023 | 04:41 PM
btartus's Avatar
I will do that! but is this the correct test kit? OTC 5609 Cylinder Leakage Tester
