1995 Honda Accord EX V6 not starting
I’ve got a 95 Accord which isn’t starting. When I turn the key, the dash lights will come on and I can hear the solenoid click, but I don't hear the starter at all. Also, every once in a while when I turn the key there is no power at all. I first tried replacing the battery with a known good one and that made no difference. If I turn the key extremely slowly it will start maybe once every 10 or 15 tries and run fine. When I turn the key and hear the starter the car starts instantly.
I ended up replacing the ignition switch both electrical & lock as well, but am still having the same issue. When replacing the battery I saw quite a bit of corrosion on the positive battery cable terminal which I removed with a wire brush. Perhaps a bad positive ground cable? Any ideas are appreciated. Thanks for the help, Josh |
If you always hear, without fail, the starter solenoid click and the starter doesn't crank then either bat is low,wiring/connectors in starter circuit or starter is intermittent.
Since you have a new bat, verify that the positive and negative wiring/ connectors( grounds to frame included) are clean/tight. If these are good that leaves the starter solenoid/starter as the problem. |
possible battery connection
I had some of the same symptoms. Realized that my negative batter cable was loose and somewhat corroded. A quick tighten and cleaning of the terminals worked well. You could also check and see if there's water in the chambers of the battery. Don't know if that would be a definite cause though. Good luck
When you wire-brushed the battery cables, did you take off the clamp & clean the actual surfaces that clamp together at the post?
How about loose/dirty/corrosion at the OTHER END of the battery cables? |
