1995 Honda Accord EX V6 not starting
Old Aug 19, 2014 | 11:04 AM
motojosh's Avatar
Default 1995 Honda Accord EX V6 not starting
I’ve got a 95 Accord which isn’t starting. When I turn the key, the dash lights will come on and I can hear the solenoid click, but I don't hear the starter at all. Also, every once in a while when I turn the key there is no power at all. I first tried replacing the battery with a known good one and that made no difference. If I turn the key extremely slowly it will start maybe once every 10 or 15 tries and run fine. When I turn the key and hear the starter the car starts instantly.
I ended up replacing the ignition switch both electrical & lock as well, but am still having the same issue. When replacing the battery I saw quite a bit of corrosion on the positive battery cable terminal which I removed with a wire brush. Perhaps a bad positive ground cable? Any ideas are appreciated.
Thanks for the help,
Josh
Old Aug 19, 2014 | 05:06 PM
cj1's Avatar
cj1
If you always hear, without fail, the starter solenoid click and the starter doesn't crank then either bat is low,wiring/connectors in starter circuit or starter is intermittent.
Since you have a new bat, verify that the positive and negative wiring/ connectors( grounds to frame included) are clean/tight. If these are good that leaves the starter solenoid/starter as the problem.
Old Aug 20, 2014 | 10:13 AM
brent97accord's Avatar
Default possible battery connection
I had some of the same symptoms. Realized that my negative batter cable was loose and somewhat corroded. A quick tighten and cleaning of the terminals worked well. You could also check and see if there's water in the chambers of the battery. Don't know if that would be a definite cause though. Good luck
Old Aug 22, 2014 | 12:56 PM
When you wire-brushed the battery cables, did you take off the clamp & clean the actual surfaces that clamp together at the post?
How about loose/dirty/corrosion at the OTHER END of the battery cables?
finfan187
Apr 15, 2013 12:03 PM
noseprints
Sep 15, 2012 12:06 PM
funkyguy
May 17, 2012 09:46 PM
LaGirl
Apr 24, 2012 05:29 PM
mark24317
Nov 14, 2011 04:57 PM
