1995 Honda Accord wont start???? PLease Help ASAP
Old Feb 27, 2013 | 08:49 PM
John Gerst's Avatar
Default 1995 Honda Accord wont start???? PLease Help ASAP
when it was running it sounded like a diesel engine, when i hit high rpms it would bog down then eventually after driving for a little bit it died. when trying to start it it didnt sound normal it was like a low sounding wooo wooo insted of a ring ring start. idk how to explain but i need help asap please.
Old Feb 28, 2013 | 12:38 AM
phantom699's Avatar
did u recently do a tune up??
perhaps your firing order for the spark plug wires are in the wrong order
oorr.. your not firing on all 4/6 cylinders.
imo i would guess that your timing is off but its not a valve tap issue, as its most likely related more towards ur spark plugs. pull the wires out 1 at a time and see if they are wet/oil/dry etc.
Old Feb 28, 2013 | 10:19 AM
John Gerst's Avatar
Default thank you
Thank you soo much for your reply! I already suspected timing belt issues but i wanted a second opinion, i have ordered a timing belt/water pump kit and it should be here today!! thanks again!
Old Feb 28, 2013 | 11:38 AM
If Check Engine Light is on, get the codes. See DIY forum for instructions.
Old Feb 28, 2013 | 12:16 PM
Maybe phantom was talking about spark timing, not timing belt. But still, that's another possibility.
What engine? The V-6 car is so much different from the 4-cyl (especially 95-97) that I wish they had called it something else not Accord.
Check engine light??
Old Feb 28, 2013 | 12:33 PM
John Gerst's Avatar
its a 4cylinder vtec turning it over doesn't even sound right, when it was running it sounded like a diesel engine, you think i may have bent the valves? i dont believe check engine light is on.
Old Feb 28, 2013 | 08:16 PM
Rotate engine to TDC (isolated timing mark on crankshaft pulley) and remove upper timing belt cover to inspect (valve cover must be lifted). Sprocket has an arrow that should be pointed up and horizontal marks between cogs that should be pointed at back side of timing belt cover.
Alternatively remove distributor cap and check that rotor is pointed to #1 tower.
If timing is good, problem is most likely spark plugs, spark plug wires, or distributor rotor/cap fault.
Old Mar 2, 2013 | 12:18 PM
John Gerst's Avatar
thanks for all the replies, but it turns out the cam broke at the end where the pulley screws into it.... bummer huh
Old Mar 2, 2013 | 01:15 PM
Wow, bummer. But that's the 2nd time I've heard of that happenning with a F-series engine.
stutla22
May 13, 2014 12:41 AM
kaneman
Oct 28, 2013 06:04 PM
boostedz06
Sep 18, 2012 09:22 AM
omerta
Jan 29, 2010 07:35 PM
RoKnAzn
Jul 11, 2007 11:10 AM
