1996 2.2 Liter - Engine Noisy On First Start Of Day
I find when starting the engine for the first time, it seems to be noisier than usual.
After at most five minutes of driving, the noise disappears. I only notice the noise when stopped at a light, which always happens. I'm using high mileage oil, and just filled up with premium gas, based on the articles I've read about carbon build-up. When the engine is started subsequently the same day, there's no unusual noise at all. Rob :) |
Two comments:
Originally Posted by shipo
(Post 344732)
Two comments:
Is a valve adjustment something Honda must do? What should this kind of work cost? OK, thanks for the info. regarding premium fuel - interesting. Rob :) |
The valves can be adjust by almost anyone.
Do you know when the timing belt and that was last changed? I ask because of the age and miles on the car - assuming the milage in your signature is correct. EDIT: I now see that the timing belt question is being discussed in another thread you have. |
