1996 2.2 Liter - Engine Noisy On First Start Of Day
Old May 2, 2014 | 10:01 AM
19962door's Avatar
Default 1996 2.2 Liter - Engine Noisy On First Start Of Day
I find when starting the engine for the first time, it seems to be noisier than usual.
After at most five minutes of driving, the noise disappears. I only notice the noise when stopped at a light, which always happens.
I'm using high mileage oil, and just filled up with premium gas, based on the articles I've read about carbon build-up.
When the engine is started subsequently the same day, there's no unusual noise at all.
Rob
Old May 2, 2014 | 10:44 AM
shipo's Avatar
Two comments:
  • It sounds like it is time for a valve adjustment; most likely the cause of your startup noise.
  • Lose the premium fuel, not good for your engine. Carbon build-up is more likely to happen with premium fuel in an engine not designed for that fuel, than using the proper fuel.
Old May 2, 2014 | 11:19 AM
19962door's Avatar
Originally Posted by shipo
Two comments:
Is a valve adjustment something Honda must do?
What should this kind of work cost?
OK, thanks for the info. regarding premium fuel - interesting.
Rob
Old May 3, 2014 | 08:50 AM
The valves can be adjust by almost anyone.
Do you know when the timing belt and that was last changed? I ask because of the age and miles on the car - assuming the milage in your signature is correct.
EDIT: I now see that the timing belt question is being discussed in another thread you have.
Bigbird74
Aug 11, 2014 10:19 PM
19962door
May 2, 2014 02:31 PM
Lunalobowolf
Oct 26, 2012 09:33 PM
HondaGirl15
May 25, 2011 05:50 PM
sthavorn
Apr 3, 2008 07:37 AM
