1996 Accord Main Relay Ground
Old Aug 21, 2012 | 11:38 PM
snerty32's Avatar
Yes all were fine
Old Aug 22, 2012 | 11:02 AM
snerty32's Avatar
I won a bid for a ECM on ebay. But I just noticed it was for a manual transmission and I have an automatic. (Stupid me, but luckily it was only $10) Would it be ok to test with to see if it solves my problem? Meaning just to start the car, not actually drive it.
Old Aug 23, 2012 | 08:25 PM
snerty32's Avatar
Anyone know?
Old Aug 24, 2012 | 08:01 PM
"pretty" sure enough to start the car......the tcu won't be happy.
Old Aug 26, 2012 | 05:26 PM
snerty32's Avatar
Im still waiting for the ECM I bought, but yesterday the car started every single time just as if nothing was wrong, all day long.
Today wont start at all again. The green light never comes on around D4 nor does the fuel prime. I took the master relay out and re-soldered all the joints again, and tested it using the relay test procedure and all is working perfect with the relay.
My question.... does the Master Relay tell the Fuel pump to prime without interaction of the ECM? Or is the ECM involved somehow?
What is the route it takes to start? Does it go from Switch > Master Relay> Fuel Pump > ECM?
Old Aug 26, 2012 | 06:51 PM
When you turn on or off a light switch, physically lifting the switch is the signal.
A relay is simply a switch, but the signal to turn on/off the circuit is an electrical signal. Hondas typically turn on/off a relay providing/removing ground. Think of it as two switches linked together. When you turn on/off one switch, the other one turns on/off.
For the MFR, the power source for the signal and the primary side is the ignition switch.
The ground is provided/removed by the ECU. When the ECU grounds the main relay, the primary side supplies power to the fuel pump.
I hope this makes sense.
Old Aug 26, 2012 | 08:45 PM
  #17
This links has info. on how the main relay works:
How the Main Relay works
Old Aug 27, 2012 | 08:01 AM
  #18
snerty32's Avatar
Awesome link. I think that answers my question, that the ECU does control the initial prime of the FP, not just the MR. So hopefully a new ECU will be the answer to my problem.
Old Aug 27, 2012 | 07:35 PM
  #19
Been seeing more and more of these recently on the 5th gens.....hummm.
Old Aug 28, 2012 | 07:28 AM
  #20
snerty32's Avatar
I bought an OBDII reader yesterday and no codes related. Only two codes I had was O2 Sensor and Variable Speed Control. Strangely when I cleared the codes the car started right up.
