1996 Accord Window and Sunroof motors
How do I change the window and sunroof motors.
Can I ask why? Seems odd that they all go bad.
Anyway, look in the DIY section, make sure to change the setting at the bottom to "show all threads", for a manual you can download. It will help with the procedure for replacing/TESTING the motors. |
my driver's side window is not rolling up or down.
what could be the possible problems here? everyone i speak with keeps referring to the regulator. has anyone had experience fixing this problem? 96 LX Manual 4 Cyl. Coupe |
jonny-might start you own thread, if you haven't already...I did not look.
There are a few tests you can preform on the motor and switch to "find" which might be the issue, Do you have a manual, if not look in the DIY section for one you can download, it will help with these tests. |
Regulator (motor and mechanism that moves the window) are fairly common failure items.
Suggest downloading the 94-97 Accord Shop Manual from Online Manuals post in DIY forum for guidance on door panel removal and regulator replacement. Not a difficult job w/ instructions. Sunroof is uncommon to fail. Most folks never move them, so parts are unlikely to wear out. Most likely it needs cleaning and lubing. good luck |
