1996 Accord Window and Sunroof motors
Old Apr 30, 2011 | 08:03 PM
charlieshore01's Avatar
Default 1996 Accord Window and Sunroof motors
How do I change the window and sunroof motors.
Old May 1, 2011 | 08:36 AM
Can I ask why? Seems odd that they all go bad.
Anyway, look in the DIY section, make sure to change the setting at the bottom to "show all threads", for a manual you can download. It will help with the procedure for replacing/TESTING the motors.
Old May 9, 2011 | 01:53 PM
jonny1996's Avatar
my driver's side window is not rolling up or down.
what could be the possible problems here? everyone i speak with keeps referring to the regulator.
has anyone had experience fixing this problem?
96 LX Manual 4 Cyl. Coupe
Old May 9, 2011 | 08:05 PM
jonny-might start you own thread, if you haven't already...I did not look.
There are a few tests you can preform on the motor and switch to "find" which might be the issue, Do you have a manual, if not look in the DIY section for one you can download, it will help with these tests.
Old May 9, 2011 | 08:07 PM
Regulator (motor and mechanism that moves the window) are fairly common failure items.
Suggest downloading the 94-97 Accord Shop Manual from Online Manuals post in DIY forum for guidance on door panel removal and regulator replacement.
Not a difficult job w/ instructions.
Sunroof is uncommon to fail. Most folks never move them, so parts are unlikely to wear out. Most likely it needs cleaning and lubing.
jam
Oct 24, 2013 08:11 PM
CDelgado
18
Feb 14, 2012 11:10 PM
tommyp
Feb 2, 2011 05:29 PM
DaIna-Kelela
Oct 4, 2010 01:16 PM
firefighter18170
Aug 19, 2008 08:45 PM
