1996 LX V6 ac problems
Old Jun 21, 2011 | 04:05 PM
fbodyrs96's Avatar
Default 1996 LX V6 ac problems
OK all new parts.
compressor
pressure switch
dyer
expansion valve
evaporator
had the system vacuumed and recharged all readings were normal and everything was running like its supposed to. but its still taking almost 30 mins to cool and even then its not cool enough to ride with the windows up.
any suggests or tips?
Old Jun 21, 2011 | 04:17 PM
phatboyslim2012's Avatar
this was brought to my attention when i was reading other posts...
looking at the heater core inlets, you will see an open/close valve on the "in" hose, that connects to the temp control next to the fan controls, check which way it travels when you turn it to the hot position, then turn it all the way to cold go under the hood and see if it will travel any further, if it does make sure the valve is closed and then adjust the cable accordingly, this will keep the heater core from blowing warm air.
Old Jun 21, 2011 | 08:19 PM
^x2, blend door adjustment can give you bad ac performance, there are actually two cables that you need to check/adjust, check the the common DIY thread a link to the manual. Also this gen is known for breaking the ****, be sure, pull it and make sure it is really going all the way to cool.
Old Jun 21, 2011 | 09:01 PM
fbodyrs96's Avatar
it already has a new ****, control valve is going all the way. I've checked all the cables that alldata shows all seem to be working properly.
Old Jun 21, 2011 | 09:20 PM
Was it taking 30 minutes to cool when you first had it charged? Have you tested the pressures since you first had it recharged?
Why did you replace all of those parts?
Old Jun 22, 2011 | 06:27 AM
fbodyrs96's Avatar
IDK the car was already running and cool when we picked it up.
compressor locked up, so changed it with the dyer and exp valve, had the evap out might as well put a new one back in.
also I know the AC works better when its cool outside, but it was still around 80 when I went to work last night and it was so cold I had to turn it off, same this morning. so why wont it work when its hot, it did before it locked up last summer...
Old Jun 22, 2011 | 02:33 PM
fbodyrs96's Avatar
OK, today on the way home everything stopped working no blower motor, compressor and lights on HVAC panel are out, cant find any bad fuses under hood, is there somewhere else to check.
Old Jun 22, 2011 | 02:56 PM
under the drivers dash there is a fuse box
Old Jun 22, 2011 | 09:09 PM
fbodyrs96's Avatar
Thanks found it, fuse was blown. AC still not working right when its hot outside.
Old Aug 10, 2011 | 05:09 PM
fbodyrs96's Avatar
OK update,
96 accord 2.7 V6
Ok I bought gauges and a vacuum pump redid the whole thing, vacuum for almost 2 hours, held vacuum almost right at -29.
87 deg 58% humidity
car off
car on low side open high side closed
car on low and high both open
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 171KB.
still takes for ever to get cool but it is cooling better know.
what else could be wrong, and if the engine rpms drop below a 1k the compressor will rapidly cycle on/off
