1996 reset engine light??
I have a 1996 Honda that we just replace the O2 sensor in, is there a way to reset it so that the Engine light will go off?
RE: 1996 reset engine light??
An OBDII scanner can erase it. Advance or auto zone can do it for you.
1996 may or may not be OBDII for the scanner reset, as mentioned above. For both OBDI and OBDII, you can pull the ECU fuse for 30 sec. to clear any codes.
