1996 reset engine light??
Old Nov 5, 2008 | 03:25 PM
nancyjanes75
Default 1996 reset engine light??
I have a 1996 Honda that we just replace the O2 sensor in, is there a way to reset it so that the Engine light will go off?
Old Nov 5, 2008 | 03:31 PM
cjdm98's Avatar
Default RE: 1996 reset engine light??
An OBDII scanner can erase it. Advance or auto zone can do it for you.
Old Nov 5, 2008 | 05:21 PM
finch13's Avatar
1996 may or may not be OBDII for the scanner reset, as mentioned above. For both OBDI and OBDII, you can pull the ECU fuse for 30 sec. to clear any codes.
jfralph
Dec 27, 2011 12:34 PM
derekcentrico
Sep 1, 2009 11:32 AM
elderfoster
May 25, 2009 02:44 AM
GELewis
Oct 3, 2008 11:02 PM
jdh72022
May 3, 2007 11:43 AM
