reset check engine light?
Old Aug 31, 2009 | 10:19 PM
derekcentrico
Default reset check engine light?
I removed the 15A fuse for the DBW (drive-by wire) system when testing a fuse extension cable. I turned the ignition on to see if a fuse extension accessory cable was going to work. After that, I put the fuse back in an started the car. Ever since then the CHECK ENGINE light has been on.
Is there a way to reset it? I'm assuming it did that because I reset the computers reading by removing the fuse and turning the ignition on...
Old Sep 1, 2009 | 12:23 AM
deserthonda's Avatar
you need a scan tool ....go to Autozone they might do it free of charge
Old Sep 1, 2009 | 07:18 AM
It'll probably also go away on it's own (since you put the fuse back in). That takes several driving cycles.
Old Sep 1, 2009 | 11:32 AM
derekcentrico
thanks a lot! it went off the third time i started it up today. awesome these hondas are...
now to figure out the air filter and i'm golden!
jfralph
Dec 27, 2011 12:34 PM
elderfoster
May 25, 2009 02:44 AM
nancyjanes75
Nov 5, 2008 05:21 PM
GELewis
Oct 3, 2008 11:02 PM
