1997 Accord Intermittent Ignition Miss
Old Apr 2, 2012 | 08:58 PM
yeagerd's Avatar
Default 1997 Accord Intermittent Ignition Miss
Hello All,
I have a 97 Accord SE. The engine has an intermittent ignition miss that mostly appears when the engine warms up. When the engine runs OK it runs great. The engine maintains RPM during AC cycling and shifting from park to reverse to forward.
When the problem starts it's just like a the ignition randomly picks cylinders to miss. Idle speed slows and the engine stalls easily.
The plugs are 2 years old and in great shape. I've just replaced the cap, rotor, wires, coil and ignition module.. Still same problem.
Has anyone experienced this? Are there any ideas?
Old Apr 2, 2012 | 09:10 PM
Clean the EGR ports. In the common diy thread on top of the gen tech help forum, there is a link to cleaning the EGR ports for the 94-97 accords.
Old Apr 5, 2012 | 11:34 AM
yeagerd's Avatar
Default My 97 Accord Is Fixed!!!!
Hello PAHonda, I was able to follow the instructions you mentioned in your reply and the Accord is running sweet.. I have to admit that I questioned this fix since the problem was so intermittent. Well, I have to tip my hat to you.. Many thanks!!
Old Apr 5, 2012 | 02:53 PM
Thanks for posting the solution, and I'm glad that it worked out.
N4chtm4hr
Jul 28, 2014 08:30 PM
mattcadieux1
May 8, 2013 08:45 PM
shehadehd
Sep 20, 2012 05:20 PM
SlyBlackDragon
Jan 6, 2012 10:13 PM
h2oskibum
Dec 5, 2010 09:44 PM
