1997 Accord New stereo
Old Jul 25, 2012 | 12:52 AM
matt1220's Avatar
Default 1997 Accord New stereo
My brother gave me his old pioneer DEH-1400 car stereo. I bought a harness and mounting kit and soldered the harness plugged it in and it powered up. I put in a CD and nothin. No sound. I went to look at the wires and looked back at the screen to see that the lights went out. it wouldnt turn back on. I plugged back in the factory radio and i noticed when i moved it around the lights on it dimmed. I tried again with the pioneer. nothin again. tried the factory and that now didnt turn on. HELP?!?!?
Old Jul 25, 2012 | 02:05 AM
94ex915's Avatar
Almost A Senior Member
What do you mean you moved around the lights on it? First thing I would check is the fuse on the stereo.
Old Jul 25, 2012 | 11:41 AM
matt1220's Avatar
I plugged back in the factory radio and as i like tipped it back and forth and moved it slightly around the lights dimmed and got brighter depending on where i was holding it.. Im assuming that its from a connection that isnt all that great. I checked the fuse on the stereo. Perfectly fine.
Old Jul 25, 2012 | 11:47 AM
matt1220's Avatar
Old Jul 25, 2012 | 02:58 PM
94ex915's Avatar
How did you connect the wires? They are probably not making a good connection. A wire could also be grounding out somewhere. I had a similar problem and there was some exposed wire.
Old Jul 25, 2012 | 04:22 PM
matt1220's Avatar
I soldred them and wrapped them in electrical tape. My dad is pretty good at it and gave me some direction. What i dont get is it powered up at first and now nothing. I have a CD stuck in there too. I did use butt connectors when it first started and then switched.
Old Jul 25, 2012 | 08:52 PM
94ex915's Avatar
Oh wow... I still want to say that something is grounding in there....
Old Jul 25, 2012 | 09:41 PM
matt1220's Avatar
I think that i might have blown the fuse in the car for the stereo. Thats kinda the way it was acting.
Old Jul 25, 2012 | 10:07 PM
94ex915's Avatar
But you had said when you move the wires it will flicker?
Old Jul 25, 2012 | 11:37 PM
matt1220's Avatar
I did. Both stereos are dead when i plug them in now.
