1997 accord problem
+1 Second approach again comes back to:
"... does the cruise control work? Does the check engine light turn on while driving?..."
Just to add a little more, PAhonda's questions were essentially to find out whether the problem is related to the VSS or the speedometer head (e.g., the printed circuit board). How you answer the questions (regarding the symptoms) should help narrow down which area is the cause.
