1997 accord problem
Old May 3, 2012 | 12:43 AM
Rcruz's Avatar
Default 1997 accord problem
Have a 1997 Accord and speedometer/odometer does not work. I also have another post with power windows not working. Is there a chance this is tied together?
Thanks
Old May 3, 2012 | 07:20 AM
crispin's Avatar
you have been here for a while - I am sure you know how to use the search feature.
VSS problems is what causes the speed / odo to stop working
Windows not working would not be related.
Old May 3, 2012 | 07:39 AM
Before replacing anything, does the cruise control work? Does the check engine light turn on while driving?
Old May 3, 2012 | 03:45 PM
Rcruz's Avatar
Thanks for response, It was the VSS. replaced it and work fine now. Only thing left it power window issue
Thanks again
Old May 5, 2012 | 10:47 AM
Rcruz's Avatar
Back to same problem, Speedo went out after driving it couple miles down the down, changed out sensor, worked then quit.
Old May 5, 2012 | 11:36 AM
Does the cruise control work when your speedometer stops working?
Old May 5, 2012 | 11:38 AM
crispin's Avatar
sounds like a bad wire at the VSS connector.
Or as PA Honda is going for, bad circuit board on the cluster.
Old May 5, 2012 | 08:07 PM
+1 This would have been the best approach first.
+1 Second approach again comes back to:
"... does the cruise control work? Does the check engine light turn on while driving?..."
Old May 5, 2012 | 08:26 PM
Just to add a little more, PAhonda's questions were essentially to find out whether the problem is related to the VSS or the speedometer head (e.g., the printed circuit board). How you answer the questions (regarding the symptoms) should help narrow down which area is the cause.
Old May 5, 2012 | 08:43 PM
Rcruz's Avatar
I just got back in, Yes Cruise control works regardless if speedo is out. Drove it down the road and started to work again. I'll check connector at sensor
