-   -   1997 Honda Accord (https://www.hondaaccordforum.com/forum/general-tech-help-7/1997-honda-accord-33375/)
gooch24 Jul 5, 2010 10:23 AM
1997 Honda Accord
I have a 97 Accord that was run thru some water. It got water in the oil, transmission, air filter and carpet. It would start the 1st couple of days after but would not stay running. Then it would not start at all. I found the fuel pump was not working. I replaced the main relay and the fuel pump works now but the engine does not turn over. The dash lights come on but when you turn the key to start it, nothing happens. No click or anything. I do notice when I turn the key on and the dash lights come on the green circle around the d4 comes on for a couple of seconds then goes out. It seems like I'm trying to start it when it's in gear. That's how it acts to me. You turn the key, everything looks pretty normal but when you go to start it nothing. I replaced the ECU because the carpet got wet but the car still wont turn over. Anybody got any ideas what to do next? Any help would be greatly appreciated. Thanks
gooch24 Jul 5, 2010 11:40 AM
It is a SE and it has a 4 cyl. engine.
PAhonda Jul 5, 2010 01:01 PM
Did you check the connections to the starter?
gooch24 Jul 8, 2010 04:16 PM
Connections look fine. I wonder if this is my trouble area. When the car stopped turning over, I also lost my power locks and the security light quit blinking. Anybody know what controls the power door locks and security system?? I think that may be what has my car shut down.
PAhonda Jul 8, 2010 05:12 PM
Do you mean the security light on the factory radio? Or do you have a separate security system on your car?
gooch24 Jul 8, 2010 06:13 PM
It is next to the radio. It's a little black rectangle with a red light in the middle. It says security. As far as I know it is a factory alarm. The fobs do not work also. I cannot set off the panic alarm. It's like it is dead.
kris_loehr Jul 8, 2010 06:24 PM
“It's a little black rectangle with a red light in the middle”
I believe that is aftermarket and may be your no crank problem
gooch24 Jul 9, 2010 03:16 PM
It could be an aftermarket system. It sure looks stock to me. It is above the radio compartment. On the left hand corner is the hazard button and the right hand corner is the security light. Did the 97's come with original security alarms? Fobs?
PAhonda Jul 9, 2010 04:27 PM
I think the 96/97 had honda FOBs, so the FOB and alarm could be a Honda accessory.
Try to find the alarm control unit and post any information (model, part numbers, etc...) off of it.
riddellr Jul 14, 2010 03:44 PM
The Honda Factory Security System in my 97 LX is located below the steering wheel at the bottom of the dash. It has a small antenna on it and a switch that controls how the alarm behaves. I would be looking for blown fuses or a bad connection.
