1999 Accord Won’t Start
I have a 1999 Accord 4-dr EX. I had the CEL on and thought I could manually pull the CEL code by using a paper clip to the OBD2 connector, which I’ve done several times in the past, but apparently didn’t do it correctly this time, as I sparked the connector, which now the car will still turn over, but won’t start. All fuses are good. I hope it’s not the ECU/PCM, any thoughts besides calling me an idiot for not taking it in to get the code read? Thanks! |
What wire colors did you accidentally short?
Originally Posted by PAhonda
(Post 380862)
Under-hood Fuse No. 46 (15A) is probably blown. Hopefully, that is the only damage.
That fuse provides power to & protects the DLC - Data Link Connector (OBD connector) and the Main Relay. |
(Post 380871)
