1999 Accord Won’t Start
Old Jun 13, 2018 | 05:28 PM
barfo's Avatar
Default 1999 Accord Won’t Start
I have a 1999 Accord 4-dr EX. I had the CEL on and thought I could manually pull the CEL code by using a paper clip to the OBD2 connector, which I’ve done several times in the past, but apparently didn’t do it correctly this time, as I sparked the connector, which now the car will still turn over, but won’t start. All fuses are good. I hope it’s not the ECU/PCM, any thoughts besides calling me an idiot for not taking it in to get the code read?
Thanks!
Old Jun 13, 2018 | 10:11 PM
What wire colors did you accidentally short?
Old Jun 14, 2018 | 07:40 AM
barfo's Avatar
I’m not sure as I don’t recall which pin holes I inserted the clip in when it sparked. I looked on the backside of the connector where the wires insert, but I can’t tell which wire(s) got fried just by looking at it.
Old Jun 15, 2018 | 11:31 AM
Under-hood Fuse No. 46 (15A) is probably blown. Hopefully, that is the only damage.
That fuse provides power to & protects the DLC - Data Link Connector (OBD connector) and the Main Relay.
Old Jun 16, 2018 | 09:36 PM
barfo's Avatar
Well, you ARE correct, that’s exactly what it was. Thanks so much!
Dbeemen
Nov 1, 2015 12:12 PM
Sheri6889
Jun 17, 2015 08:19 AM
polarihog
Feb 17, 2012 05:54 AM
josh.roy35
Sep 23, 2011 07:39 PM
josh.roy35
Apr 26, 2011 01:56 PM
