1999 Honda Accord Won't Start
Old Oct 30, 2015 | 09:34 AM
Dbeemen's Avatar
Default 1999 Honda Accord Won't Start
I just put a brand new starter on my car yesterday because my sister went through high waters. I been trying to get my car started but it just wont start at all, i pulled all the spark plugs, hooked everything back up correctly so what should i do the sew wats really wrong now
Old Oct 30, 2015 | 10:21 AM
shipo's Avatar
Hydrolocked the engine? If so it is time for a new motor.
Old Nov 1, 2015 | 05:28 AM
What is happening when you try to start the car?
Old Nov 1, 2015 | 08:59 AM
Dbeemen's Avatar
The engine act like it wana start but it wont fully start so what should i try to do
Old Nov 1, 2015 | 09:02 AM
Dbeemen's Avatar
It will try to start up then i start hearing a clicking and everything will just cut off.
Old Nov 1, 2015 | 10:14 AM
Suggest treating as a typical No-start. What's missing fuel or spark?
A simple test is to attempt to start w/ starter fluid or throttle body cleaner. A 5-10 sec blast into the air intake followed by attempt to start.
If it starts briefly and runs, then spark is good and fuel delivery is problem(no/low fuel pressure or contaminated fuel).
If it doesn't start, the no spark is likely and testing for power to distributor, ECM control pulses to ignitor module to determine reason for no spark.
Old Nov 1, 2015 | 12:12 PM
Dbeemen's Avatar
Okay thank you
Sheri6889
Jun 17, 2015 08:19 AM
polarihog
Feb 17, 2012 05:54 AM
josh.roy35
Sep 23, 2011 07:39 PM
josh.roy35
Apr 26, 2011 01:56 PM
1999AccordEXinNM
Mar 29, 2010 07:33 PM
