Seat belt warning light is on, but the chime does not beep
Old Nov 1, 2015 | 02:20 AM
neocns's Avatar
Default Seat belt warning light is on, but the chime does not beep
Hi,
I have a Honda Accord Coupe 2005, EX. Recently I find that when I do not wear the seat belt, the warning light is on, but there is no beep.
I would like to get it back. Could someone give me advice on how to diagnose this?
Thank you.
Neo.
Old Nov 1, 2015 | 10:09 AM
I looked at wiring diagram for Reminder Systems in Honda Shop Manual. The wiring diagram suggests two possibilities; the beeper speaker has failed, or wiring fault in the beeper speaker cicuit; damaged wire or loose connection.
The reminder system is part of the gauge control module (gauge panel) and would have to be removed to perform tests.
Do you not get beeps for key in ignition, lights On? Appears to use same beeper so this would confirm beeper fault if no beeps.
Old Nov 1, 2015 | 11:52 PM
neocns's Avatar
Thank you for the information.
I do get beeps for key in ignition, and the lights on. Then it means there should be something wrong with the wire, I guess.
Old Nov 2, 2015 | 09:27 AM
Sound for other reminder systems suggests a fault on the "front end" side of the circuit (specific to seat belt reminder). There are a resistor, LED, and driver circuit in series. Fault could be any of these or a circuit board defect (bad solder jts are a common fault in gauge panels).
It may not be worth the effort to revive this circuit. In any case you need a Honda shop manual to guide gauge panel removal and diagnosis. It may be cheaper to simply replace the panel, but this may require getting mileage corrected to match vehicle mileage.
A download shop manual can be purchased from automanualsource.com for $22. Check Online Manuals post in DIY forum for other possible download sources.
Old Nov 2, 2015 | 01:29 PM
neocns's Avatar
Thank you for your reply. It is too complicated, and probably I will just leave it there.
trijoon
Nov 15, 2010 09:54 AM
cfoxmd
Jan 25, 2009 07:35 PM
AccordCroz
Nov 16, 2007 09:23 AM
lacrw
Aug 1, 2007 08:43 AM
eckhart
Jun 29, 2006 07:02 PM
