2000 3.0L alarm or immobilizer? (remote start insall question)
Looking to possibly get a remote start for a 2000 accord 2dr 3.0L (LX i think)
Does this car have any kind of factory alarm or immobilzer that would interfere with a remote start installation? The car doesn't currently have keyless entry |
RE: 2000 3.0L alarm or immobilizer? (remote start insall question)
On mine, there was a part that had to be bought from Honda .... supposedly. I wouldn't be surprised if that was just the shops excuse for not finishing the job ...... I think the -special part- was a relay.
Anyway, the part needed was to bypass the immobilizer for the auto-start function. Prior to the fix, the auto-start would work only with the key in and on. |
Yes, there is an immobilizer in the key cylinder and a chip in the key itself.
So it needs one of those things where they put a spare key into a box under tha dash with a coil of wire wrapped around it? or does it bypass the immobilizer entierly? does that make the immobilizer totaly non-functional anymore?
Are you doing this yourself or having a shop do it?
haven't decided yet, but i'm not going to do it if it's one of those jerry-rigged kind of things.
It shouldn't be, it's most likely a box you can place in between the ignition wires beneath the dash. I installed my alarm and it wasn't so bad. What brand and model are you looking at?
Haven't decided on brand/model yet. just investigating the feasability.
I knowsomebody whohad problems with integration with afactory alarm ina car. is the bypass module a Honda part, or made byremote start manufacturers? |
It's not Honda I know that... I'm just trying to think... because I didn't have to bypass my immobilizer to install my alarm, but obviously I never use the car without the key.
Looks like i answered my own question. Bulldog says this car needs the "791 Universal Bypass Module" http://www.bulldogsecurity.com/MTweb...ts.asp?id=1007
Please Note: If your vehicle has a Transponder anti-theft system, you will also need an additional key to put inside the 791 bypass a spare key put inside a box under the dash definitely fits my idea of jerry-rigged. I think i'll pass on the remote start. |
