2000 Accord leaking oil, please help
Old Jan 22, 2011 | 10:59 AM
kyleshondar's Avatar
Exclamation 2000 Accord leaking oil, please help
Hey all, i have a 2000 Honda Accord 4cyl atoumatic, i just needed all the help and input you guys can give, I was at the local quickshop when a buddy of mine told me my oil looks like its leaking, sure enough i got down and there was a huge pile and it was stil going, this isn't small leak i mind you but a large leak, i don't think i let it warm up as long as i usually do, anyway my dad towed it home for me and we didn't start it at all (my friend said i might seize my engine if i did, he also said i might have cracked my engine block) I just wanted to know what you guys thought since i know you have much more knowledge than me and my dad combined, also when i take it to the shop i don't want to be completely dumbfounded. thank you in advance, anything helps.
God Bless,
Kyle
Old Jan 22, 2011 | 12:29 PM
It probably is the balancer shaft seal. See this TSB, although it list it for the 5th gen Accords, the same problem also caused problems with some 6th gen Accords like yours. Good thing you didn't drive it and towed it. The seal should be replaced and the retainer installed.
tegger.com/hondafaq/tsb/accord/x00-073e.pdf
Last edited by redbull-1; Jan 22, 2011 at 01:30 PM. Reason: typo for generation numbers.
Old Jan 22, 2011 | 12:35 PM
thank you my friend, i saw that but didn't know i would see that in a 6th gen. what do you think the cost should be?
Old Jan 22, 2011 | 12:44 PM
How many miles are on the car and has the timing belt ever been replaced? IIRC, the regular timing belt change interval for your car should be 7 years or 105,000 miles.
One of my friends 2002 Accord 4 cylinder last year had the same thing happen. He had the timing belt, water pump, seal, accessory belts replaced and the retainer installed, he told me the dealer charged him something like $700 - $800. You can always call the dealer and some independent shops to get an idea what they will charged. Many times the 2 belt tensioners should also be replaced too when changing the timing belt.
Old Jan 22, 2011 | 12:47 PM
201,xxx, im not sure, it was given to me by my parents but they never had a problem with it they said, thats better than having to get a new engine, thank you very much for your help
Old Jan 22, 2011 | 12:49 PM
If you decide to go with a dealer, check their internet website for service coupons first.
Old Jan 22, 2011 | 01:00 PM
never thought of that...
Old Jan 23, 2011 | 07:45 PM
Without saying where the leak is located, it could be several other things too. The shaft seals are over towards the left side of the car. See a plastic cover way over on that side of the engine? Down at the very bottom of that is where the oil would leak out, IF it's the balance-shaft seals.
I kinda thought they had fixed that issue before 1998, but not real sure about that.
Old Jan 23, 2011 | 08:18 PM
It was more rare on the 6th gen Accord 4 cylinders; but, still happens. Here is just another example:
bernardsblog.blogspot.com/2008/09/honda-balance-shaft-seal-pop-out.html
barticus520
Aug 10, 2013 01:13 PM
JimTrail
Aug 8, 2012 08:17 AM
jaytonik
Jan 26, 2011 04:25 AM
gimme789
May 3, 2007 12:11 AM
chevync20
Aug 18, 2006 03:42 AM
