-   -   2000 Accord-SRS and Malfunction Lamp On (https://www.hondaaccordforum.com/forum/general-tech-help-7/2000-accord-srs-malfunction-lamp-64604/)
fugrwe May 12, 2017 09:19 PM
On my 2000 Honda Accord EX (V6), I removed Number 9, 7.5 Amp fuse from under the driver's side dash board by mistake. After re-inserted it back in place, the SRS and Check (Malfunction Indicator) Lamps stay lit. Is this a real problem or will the lamps go out on their own? Does something need to be reset? How to do it?
I was investigating the passenger windows-front and rear- not working; however, the driver's side window is fully functional. Any sound and concrete idea/fix for this problem also.
Thanks, and Respectfully,
Fugrwe
poorman212 May 13, 2017 01:34 PM
Can you scan for codes? I can't think of why just removing and replacing that fuse would cause an issue.
fugrwe May 14, 2017 11:41 AM
I did not replace the fuse, but reinserted the same fuse, and I never disconnected, removed or replaced anything else--no jiggling of wires or connectors. I will try to have AutoZone do a scan and will let you know the code(s).
By the way, any suggestions on why the driver's side windows work, but not any of the other windows? I am the original owner of this Accord EX with 102,000 miles and always serviced timely and properly.
Thanks and respectfully,
Fugrwe
poorman212 May 14, 2017 12:44 PM
Replace/remove and reinsert.....the same in my book,sorry about the wording.
fugrwe May 15, 2017 12:38 PM
AutoZone scanned --small hand-held scanner--with result of P0420 Code, Bank 1 Catalytic Converter. Their scanner does not scan for the SRS system nor could it diagnose the passenger windows issue.
I disconnected the battery for a few minutes, then reconnected the battery resulting in the Check Engine light NOT illuminating. However, the SRS light still comes on. Is there a reset procedure for the SRS System?
Any sugestions for the SRS and passenger windows being inop?
Fugrwe
poorman212 May 15, 2017 06:05 PM
Yes, there is a re-set for the SRS. As for the windows working/not working we can get into that after.
fugrwe May 15, 2017 06:52 PM
Will you be kind enough to provide the procedure/steps for the SRS Reset?
After this fix, the same goes for assisting in the passenger windows.
Thanks and Respectfully,
Fugrwe
poorman212 May 18, 2017 06:07 PM
1 Attachment(s)
For the SRS, here is the procedure from the service manual. I'm sure there are vidros on the internet as well.
fugrwe May 20, 2017 11:12 AM
Thanks, this procedure worked on my first try. Most appreciated.
Do you have a fix/recommendation for the passenger windows not functioning? The driver's side window works.
Thanks, and respectfully,
Fugrwe
poorman212 May 21, 2017 07:34 AM
First - don't take this the wrong way - since you have come back to this thread, I'm going to move it to General Tech for more views. Too many times in the "New Member" section you get a "one post and done" type of thing.
It could be something with one of the "multiplex" units. Most likely the driver side :shrug: - that is a guess, don't replace anything on a guess. I would start with moving to the pass side fuse box and check the fuses there - #12 and #15
