2000 Accord v6 VTech
Old Mar 24, 2020 | 07:31 AM
Honda info's Avatar
Default 2000 Accord v6 VTech
Trying to figure out where to start looking for this massive oil leak. Wet around front of engine, cam seal? Not sure but I don't have a lot of experience with this car so help is needed and appreciated. Going to check PCV TODAY. OIL IS FINDING ITS WAY TO THE WHEELS IF THAT HELPS give an idea how bad it is
when daylight appears I will had a picture or 2
Old Mar 24, 2020 | 07:43 AM
shipo's Avatar
Cam seals are a pretty common leak source for the J-Series engines. The seals started leaking on both my J30 and J32 at around 150,000 miles and 14 years. I am now firmly in the camp of replacing those seals when the Timing Belt service is performed, even if they're not leaking.
In your case, since the leak is significant, it sounds like you need to do the Timing Belt service, along with a new water pump, have the oil pump resealed, and replace the front main crank seal and the cam seals.
Old Mar 24, 2020 | 12:30 PM
Honda info's Avatar
Thank you for your input. I'm old school and haven't twisted wrenches in some time although I was thinking along those lines just not as complete as you.
Hot Brass
Sep 21, 2014 08:47 AM
Ramos95
Apr 9, 2011 09:58 AM
bambooyou
Sep 16, 2008 11:59 AM
bsnyd09
Apr 9, 2008 09:53 AM
tomaco
Apr 19, 2006 09:02 PM
