2000 Honda Accord - All Dash Lights Intermittent
Old Oct 4, 2017 | 09:09 AM
Jon Moore's Avatar
Default 2000 Honda Accord - All Dash Lights Intermittent
Good Morning,
I've seen stuff like this posted a few times, mines differs slightly. I own a 2000 Honda Acoord 2.3 Vtech. Yesterday all the lights on my dash lit up and was acting extremely sluggish. Checked Voltage at alternator, showed 10.4V. Changed the alternator last night after charging battery. Checked alternator afterwards and read 14.6V. Drove car and all the lights and sluggish behavior was gone.
Fast forward to today, as I was driving to work; all dash lights illuminated, flickered a few times and then went out. There is no timing associated with this, as the lights will flicker sporadically as compared to staying on completely like before. I am going to check grounds this evening and also disconnected my stereo amp then drive around some to see if that works. Anyone have any ideas? Any help is greatly appreciated.
Jon
Old Oct 4, 2017 | 07:20 PM
Intermittent problems are difficult to diagnose.
You may want to hook up your volt meter on the battery while the engine is running. Try shaking the battery cables to see if you get a change in voltage.
The wiring to the alternator is something else to check this way. Be very careful when working around an alternator with the spinning pulley.
Does the 2000 accord have an auto-tensioner for the serpentine belt?
Old Oct 6, 2017 | 08:07 AM
Jon Moore's Avatar
The alternator is the tensioner on this model. It isn't intermittent as much anymore, but still happens. May replace battery and see if it's just charge issue. It don't know if it's a short as it doesn't happen in response to vibrations or shakes. Confusing the crap out of me
Old Oct 6, 2017 | 06:57 PM
Is the problem only with the dash lights? Do the gauges still work when this is happening?
The best way to isolate the problem is to figure out which items are acting up when it happens, then you can start narrowing down the circuit by observing what is flickering.
John Paul Zilvetiz
Dec 31, 2015 12:32 PM
mattcadieux1
May 8, 2013 08:45 PM
okuyala
Mar 18, 2012 08:32 AM
SlyBlackDragon
Jan 6, 2012 10:13 PM
jayy123
Nov 1, 2011 09:36 PM
