2000 honda acord ex 4 cylinder has oil engine leak
Old Oct 18, 2013 | 01:01 PM
See attached image:
Attached Thumbnails 2000 honda acord ex 4 cylinder has oil engine leak-1998-2002-accord-ecm-reset.jpg
Old Oct 18, 2013 | 02:53 PM
Redbull beat me to it...
Old Oct 22, 2013 | 01:21 PM
robertng1's Avatar
Hello jim,
The check engine light code say P1706 would that be the tranmission neutral switch or faulty wiring.
Old Oct 22, 2013 | 01:23 PM
robertng1's Avatar
The check engine light code is P1706 would that be the tranmission neutral switch or faulty wiring.
Old Oct 23, 2013 | 06:14 PM
The 1706 is for the trans range switch. Several things to check/test before replacing anything.
Old Nov 3, 2013 | 04:39 PM
robertng1's Avatar
I had an engine light P1259. What should I do to fixed the problem ? 2000 honda accord ex 2.3 L
Old Nov 5, 2013 | 06:26 PM
  #17
Check the oil level first...if close to being due, change it.
Reset and see if it comes back......then we can get into more.
Old Nov 6, 2013 | 12:28 PM
  #18
robertng1's Avatar
mr. poorman I had the oil change 3 days ago and the level is fine and also reset it , the engine light not going away the problem been at least 10 months.
Old Nov 9, 2013 | 06:37 AM
  #19
Can you check for continuity between the pins on the vtech oil pressure switch?
Old Nov 11, 2013 | 11:53 AM
  #20
robertng1's Avatar
HOW to check the continuity between the pins on vtech oil switch ?
