2000 in idle rpm's jumps or bounces up and down
Old Mar 26, 2010 | 09:45 PM
Sure, just like any computer... Garbage in, garbage out.
If the ECU is getting bad information from the Vehicle-Speed-Sensor, it'll send the corresponding bad signal to the SPEEDOMETER. (Not to the tach.)
Old Mar 26, 2010 | 10:36 PM
chip's Avatar
Ahhhhhhhhh!!! That's what I was lookin' for! Thanks!!!
Old Mar 26, 2010 | 10:37 PM
chip's Avatar
What part of Ohio are you in? I'm from Cincy.
Old Mar 27, 2010 | 11:16 AM
Akron/Canton area
Old Mar 27, 2010 | 07:49 PM
chip's Avatar
okay. buckeyes represent!
Old Mar 27, 2010 | 08:32 PM
rpowers2002's Avatar
Jim, I have noticed something like what you are describing with the tachometer bouncing up and down but only when the car's speeds are below 45-50 MPH and the engine speed (according to the tach) is below 2k RPM. Would this be related to the IAC like you stated above? Mine is a 02 Accord 2.3 with the auto. Thanks
Old Mar 28, 2010 | 09:22 AM
  #17
IF it's in gear & you're driving, then you should be able to notice whether the engine RPM is actually going up & down.
If it's perfectly smooth, then it can be a problem with the wiring from ECU to tachometer. Flaky connection at the back of the cluster??
If the RPM is actually going up & down, that might be the auto-transmission hunting between gears. Without driving it firsthand, hard to say whether that's a tranny problem or just kinda normal. That's one of the "features" that makes me dislike auto-trans.
Old Mar 28, 2010 | 10:35 AM
  #18
You can feel it while the Tach is going up and down. At first, I thought it might be the plugs and changed those. The EGR valve has been changed and the ports cleaned (I don't know how well it was done bc I didn't do the work on that), the catalytic converter has been replaced, and the transmission has been rebuilt. I want to say the problem is being caused by the torque converter (which was replaced at the same time as the trans). I have taken it back to the transmission shop that rebuilt it and he swears it is the engine skipping, but I beg to differ. I have an Auto xray scanner and there are no codes stored. Thanks
Old Mar 28, 2010 | 11:05 AM
  #19
chip's Avatar
What about the solenoid packs?
Old Nov 9, 2021 | 11:16 PM
  #20
Xanda's Avatar
So what if that same thing is happening with a manual transmission? Driving a 03 Acura RSX
