2000 Transmission Shift point
Hello. This is my first post. I have a 2000 Accord LX 2.3 with almost 158,000 miles and an automatic trans. At times, and most particularly 3rd to 4th gear, I have to rev the engine upward of 2700 to 3000 RPM's to get the transmission to shift -- but only when going downhill; this does not occur on level or upward grades. It use to shift at lower RMP's. I'm thinking it's something to do with the grade logic transmission. Any ideas?
I'd check for any stored codes in the PCM.
When was the last time the trans fluid was changed? |
(Post 359342)
Many parts stores (outside of CA) will scan for codes for free, just be sure to get the actual code and not their description of the code.
There are some codes that will not "trip" the CEL/MIL light so it is worth checking. |
Update: replaced +/- 5 quarts with Valvoline Maxlife ATF and 10 oz Lubegard Red. Replaced ECT sensor and air filter. Reset computer. Shifts are almost perfect.
Update: Hanging 3rd gear appears to be related to the Grade Logic feature. If I tap the brake pedal a few times, it will up-shift into 4th.
