2000 Transmission Shift point
Old May 2, 2015 | 12:04 PM
2000LX2.3's Avatar
Default 2000 Transmission Shift point
Hello. This is my first post. I have a 2000 Accord LX 2.3 with almost 158,000 miles and an automatic trans. At times, and most particularly 3rd to 4th gear, I have to rev the engine upward of 2700 to 3000 RPM's to get the transmission to shift -- but only when going downhill; this does not occur on level or upward grades. It use to shift at lower RMP's. I'm thinking it's something to do with the grade logic transmission. Any ideas?
Old May 3, 2015 | 05:20 AM
I'd check for any stored codes in the PCM.
When was the last time the trans fluid was changed?
Old May 3, 2015 | 08:53 AM
2000LX2.3's Avatar
Thank you for the reply. How does one check for stored codes? What tool is needed? As for the fluid, it was last flushed (cooler line) about 5000 miles ago with Valvoline Maxlife and one bottle of Lubegard Platinum. This shift problem, however, started last summer before the fluid change. At that time, the transmission was using Honda DW-1 and one bottle of Lubegard Red.
Old May 3, 2015 | 09:57 AM
Many parts stores (outside of CA) will scan for codes for free, just be sure to get the actual code and not their description of the code.
There are some codes that will not "trip" the CEL/MIL light so it is worth checking.
Old Jan 24, 2016 | 03:46 PM
2000LX2.3's Avatar
Update: replaced +/- 5 quarts with Valvoline Maxlife ATF and 10 oz Lubegard Red. Replaced ECT sensor and air filter. Reset computer. Shifts are almost perfect.
Old Nov 25, 2017 | 03:19 PM
2000LX2.3's Avatar
Update: Hanging 3rd gear appears to be related to the Grade Logic feature. If I tap the brake pedal a few times, it will up-shift into 4th.
DA KID RYU
Oct 6, 2009 09:26 PM
03LUX
Oct 18, 2007 01:55 PM
louisville_slugger89
May 14, 2007 10:37 AM
tiger94
Mar 31, 2007 09:55 AM
19Accord97
Feb 22, 2007 11:48 PM
