2001 honda accord check engine - d4 blinking
Old Feb 2, 2013 | 09:07 AM
drfence's Avatar
I went to 2 shops. The best was WTR Transmission in Buford, Ga ( WTR TRANSMISSIONS - Home ). I was told he's a Honda specialist. He had a great demeanor and when I showed up he said he wanted to take it out for a test drive. When he got back he told me immediately what was wrong. He said where the transmission meets the engine ( forgetting what that's called ) there is a fiberglass ring and that's deteriorating. He said there were also fiberglass pads for each gear that were deteriorating. He said the transmission was "dying a slow death" but that it wasn't going to strand me anywhere. He told me when the car got bad enough to where it really bothered me to bring it back.
Their pricing was 1/2 that of the other shop I saw in town and his warranty was 3x the length. I highly recommend these guys.
Old Feb 2, 2013 | 12:38 PM
Good to hear you found a "good" shop.
Old Feb 4, 2013 | 10:29 PM
my986thgen's Avatar
These trannys are known to go bad i had to replace mine i did severak fluid changes and it helped a little. but all in all it needed a new tranny Good luck
Old Jun 17, 2013 | 02:17 AM
jtimc7's Avatar
drfence:
Have you been able to get your transmission problems fixed yet?
I have a 2000 Accord LX that I am having the exact same problems with.
Thanks!
Old Jun 22, 2013 | 07:57 PM
666's Avatar
666
I have a Honda 2000 v6 ex........I get code 0780 & 0730 ......
I already replaced selenoids.......same problem......the car will not shift gears.....
I have been reading ......I do not get it......should I replace the oil....please help
I also changed the oil .......but I have not used Honda oil.....
the transmission will shift better in manual mode...
Thank you very much.......
everything is back to normal with my car..........
all I did is replaced the oil......
one last thing .....how do you get rid of the check engine light
Old Jun 25, 2013 | 07:23 AM
666, go to someplace like AutoZone & have them read the error code. Get the actual code number (P1234 or something like that) not just the guy's explanation. You get rid of the CEL by fixing the problem.
You can clear the CEL by removing fuse #13 in the right dashboard fusebox (near the right-front door hinges). Remove that fuse for 20 or 30 seconds then put it back. But the CEL will come right back on if the problem isn't fixed.
Old Jun 26, 2013 | 04:20 PM
  #17
666's Avatar
666
Thank you guys.........I did everything you told me....
car is running great.....
Old Jun 27, 2013 | 06:41 AM
  #18
So... did you get the error codes from the check-engine light?
Old Jun 30, 2013 | 04:01 PM
  #19
666's Avatar
666
the code I had p0850
Old Jul 1, 2013 | 09:26 AM
  #20
666's Avatar
666
my mistake.......codes I had were 0730 & 0780
sorry about that.......
