2001 Honda Accord Timing Belt Issue
Old Jan 13, 2014 | 12:54 PM
tdsilk's Avatar
Default 2001 Honda Accord Timing Belt Issue
Hello,
I'm DYIing my first timing belt change on my 01 accord. I was able to get 3/4 of the steps done, but ran into a problem getting a stuck keyway key out of the crankshaft balancer (I guess that's the name???). Any ideas are greatly appreciated?
Thanks,
Troy
Attached Thumbnails 2001 Honda Accord Timing Belt Issue-crankshop1.jpg   2001 Honda Accord Timing Belt Issue-stuck-key.jpg
Old Jan 13, 2014 | 02:44 PM
Can you get the sprocket off anyway without removing the key? Maybe then you can grab the key?
Old Jan 13, 2014 | 03:08 PM
tdsilk's Avatar
Jim, the sprocket seems to be restricted by the key. I'm really having a problem getting behind the key to knock it out. I currently have the engine on a jack. How low can I lower the engine? If I can get the engine lower I may have more room to get behind it. Also, are there any of the other parts around the key that I should worry about damaging?
Thanks,
Troy
Old Jan 13, 2014 | 06:09 PM
kris_loehr's Avatar
Get a gear puller and put the crank bolt back in first to protect the threads.
Old Jan 13, 2014 | 08:13 PM
tdsilk's Avatar
Won't the gear be restricted by the key?
Old Jan 13, 2014 | 08:27 PM
kris_loehr's Avatar
The gear should come off with the key in place
Old Jan 13, 2014 | 08:50 PM
tdsilk's Avatar
Ok. So it sounds like once the gear is off I can proceed with removing the last belt and leave the key in place?
Old Jan 14, 2014 | 08:59 AM
Unless there is damage to the sprocket, the timing belt can be removed w/o removing sprocket.
Old Jan 14, 2014 | 09:52 AM
See # 15,16,17,18 in the picture. Be careful about that shaped tab on the back of the inboard sprocket. It triggers the CKP/TDC sensor.
It's tempting to take it all off just to be correct, but like Tex says you should be able to replace the belts.
Can you file the mangled end of the key (jeweler's file), to allow the sprockets to come off? Then grab the key? My fear is don't file TOO MUCH off, just in case you cannot get the key out after all.
I've never had to deal with this, the sprockets just pulled off without much difficulty.
Old Jan 14, 2014 | 09:57 AM
Hicksvilleshick's Avatar
x2. it could be a pita tho.
