2002 accord cylinder misfire
Old Apr 7, 2011 | 05:54 PM
outsidethewall's Avatar
Question 2002 accord cylinder misfire
Hi all,
I was experiencing jerks when driving on highway. Now there is jerk when the car is in idle. Couple of days ago the check engine light lit up. I went to local auto store to get the code. It had 5 defects. All of them point toward misfiring engine. Basically 3 of my 4 cylinder are misfiring. Anyone suggestions??
P.S. I am new to DIY. I changed the brake pads recently with the help of DIY in this forum.
edit approx. 120000 in the car
Old Apr 7, 2011 | 06:01 PM
Take a look in the owner's manual to see when you should change the spark plugs. When were the spark plugs last changed?
Old Apr 7, 2011 | 06:07 PM
It has been a long time since I changed the spark plugs. I will change it and see if it helps. Thanks
Old Apr 7, 2011 | 06:35 PM
Your accord uses platinum plugs, so they should last a long time. I can't remember the maintenance interval, but your owner's manual will have that info. I think that they last 90K.
Always use NGK or Denso plugs recommended in the owners manual. NGK PZFR5F-11 are the ones that you want.
Bad gas can cause some problems.
Also, post all of the error codes that you got. The start with the letter P and have 4 numbers, like p1234.
Old Apr 7, 2011 | 11:40 PM
I read the code in a local store. I don't remember the code numbers. The descriptions were cylinder 1 misfire, same with 2 and 3, fourth one was something like random misfire however I don't remember the last one.
Also I bought the spark plugs. It is platinum plugs. I will check if they are NGK PZFR5T-11. The store employee recommended the plugs and I got it.
PS bought the car from a friend, not sure when he last changed the spark plugs
Old Apr 8, 2011 | 02:41 AM
If you are ok with spending the money on new spark plugs, then try it. I hate advising people to throw money at their car, but this is a maintenance item.
Old Apr 8, 2011 | 10:14 AM
Sgt.Mason.Willis's Avatar
I'd say bad gas too. no reason for you to have 3 of 4 cylinders misfire.... put some new gas in it and run some fuel injector cleaner through it. change spark plugs if you want they're cheap enough. make sure you gap the plugs. if its running better after the injector cleaner just go through another tank and have your shop reset the codes so your engine light goes off. this recently happened to my fiances car because it was sitting with the same gas for a few months runs great now.
Old Apr 8, 2011 | 06:27 PM
Will change the sparks and put in some fuel injector over the weekend. Will update how it works out. Thanks
Old Apr 11, 2011 | 09:14 PM
Changes the spark plugs and the car seems to be running good. Thanks forball the help. I did put in some fuel cleaner and changed the filter as well. However the check engine light is still on.
Resatimm
Apr 28, 2016 05:56 PM
Devon7234
May 25, 2014 09:22 AM
Stimn11
Dec 15, 2012 03:59 PM
bobrae2011
Aug 5, 2012 09:35 AM
