2002 accord lx
Old May 31, 2012 | 08:27 PM
coalchugger's Avatar
Default 2002 accord lx
just bought car and coulpe things 1 right side blinkers dont work. already put new bulbs in left works fine so not a fuse.2 radio comes on and goes off at random.and sometimes it comes on but no sound
Old May 31, 2012 | 09:03 PM
Do the hazards work properly?
Old May 31, 2012 | 09:10 PM
crispin's Avatar
Welcome to the forum.
What does Coal Chugger mean? Never heard of that nickname before.
For the radio - sounds like the unit is going bad.
Old Jun 1, 2012 | 05:21 AM
hazards only work on left side
Old Jun 1, 2012 | 05:24 AM
diesel junkie my truck blows black smoke
Old Jun 1, 2012 | 06:10 PM
You will need a volt meter to do some testing.
Unplug the bulb that is not working. Turn on the hazards. Check for pulsing voltage to the non-black wire to ground (any bare metal bolt nearby will work).
Old Jun 1, 2012 | 06:28 PM
crispin's Avatar
That would be an over-fueling problem.
Reduce the amount of fuel going to your motor and you will get better MPG's as well as kill less baby seals.
Rolling Coal is about as cool as Parkinson's Disease.
As for the blinkers on the Honda I bet PA Honda's test is going to show that you do have voltage to the bulbs which will mean a bad ground, most likely corrosion in the bulb connector. That would be my guess.
HERKENG
Apr 11, 2012 02:22 PM
mike.stribling
Jul 14, 2010 01:08 AM
StatzFinest
Feb 10, 2008 11:32 AM
lothar
Dec 13, 2005 02:41 AM
tigergod2k
May 24, 2005 03:18 AM
