2002 Honda Acoord lx 2.3 vtech
Old Mar 2, 2014 | 11:14 PM
foregel's Avatar
Default 2002 Honda Acoord lx 2.3 vtech
Hello all, i just purchased a 2002 honda accord v 4, automatic, 2.3 vtech engine. The problem im having is the following. Seems like the transmission slips when shifting from 2 to 3 gear only. The shift is not smooth rather rough at times otherwise the car runs great. I took the car to my mechanic and ran it through the scanner and nothing pop out as being wrong, i took it to autozone as well they found nothing. I changed the transmission fluid, seems like i had never been changed before it was literally black so i drained it 2 times. I used the Valvoline max life fluid, i drove the car around 200 miles today the car seemed to run smoother but still jerks. Anyone else have this issue or have any recommendations?
thanks
Old Mar 3, 2014 | 09:11 AM
Flaring rpm during shift is usually a symptom of worn clutch for 4th gear. Flaring shift can be tolerated for a long time by slightly reducing throttle near shift point.
A misadjusted trans shift cable can also cause this symptom and is repairable. It is described in Honda shop manual in details too long to describe here. Suggest purchasing ($22) an emanual from automanualsource.com.
localstoner
Oct 25, 2013 05:56 PM
infectedmushroom22
Apr 17, 2013 05:18 PM
firefunk
Nov 27, 2011 02:15 PM
brinriha
Jul 2, 2008 09:28 PM
nwj917
Jan 17, 2008 01:24 PM
