2003 Accord V6 Issues
Old Jun 6, 2008 | 12:11 PM
t00fatt's Avatar
Default RE: 2003 Accord V6 Issues
Had any of you changed your ATF frequently? I'm chaging mine soon at 30k miles. In my haynes manual it says if temps excede 90f frequently and/or heavy city driving it should be changed every 30k. It says normaly to change the ATF 90k miles, but thats a long time for me.
Old Apr 30, 2013 | 07:19 AM
Daniel Potter's Avatar
i have a 03 v6 and my ca also went searching for 3rd gear i replaced the 2nd gear shift solenoids a and b and it was back to normal i just did it yesterday 4/29/'13 is it a perm. fix well i am not sure as its just been repaired and this is not the first time the car had this same issue i did a factory recall search and found it had been serviced for this same issue somewhere in cale when and where they couldnt tell me but it has happend before
this is my first and last honda im going back to Toyota after i sell this one
Old Apr 30, 2013 | 08:51 AM
shipo's Avatar
So you have a ten year old used car with some issues and you're using that to justify switching brands? I don't understand.
Old May 2, 2013 | 06:44 PM
[QUOTE=shipo;320218]So you have a ten year old used car with some issues and you're using that to justify switching brands? I don't understand.[/QUOTE you dont have to understand!!! i have a 03 with 160K on it and it is a lemon and with the research i did on the vin through the dealer, i found many issues it had before!! from the rear main seal going out for the second time !!!!and this tranny issue it commonly has!!!!!!!! and i have always owned Toyota till this lemon so its going back to what i am familiar with and have had such good luck with over the years hell even my old mercury mountaineer was a better more dependable ride with 196k on it when i sold it!!! and all i ever did to it was oil changes every 5 k and a cv shaft yep a FORD out did a honda now that is sad
frankenstein69
Dec 28, 2014 12:36 AM
Ineedhelp
Jan 22, 2012 07:29 PM
GOT BOOST
Nov 2, 2009 08:32 AM
doistrakh
Jan 26, 2008 10:00 AM
msheehan
Mar 31, 2005 01:18 PM
