2003 Coolent leak
Old Feb 11, 2016 | 08:56 AM
Zhen's Avatar
Default 2003 Coolent leak
I have 2003 Honda accord with over 200k on it. The cars runs very good and I intend to keep it to the end.
Yesterday I ran over a hump, a bit too quick. In the evening I saw temperature was high and then saw steam. I pour water in and managed to get car back home.
This morning I saw the leak point, it was below the starter but there is no hose...
Anyone know what is below the starter that could cause the leak?
I think it is the starter - on the left side laying flat close to the engine body.
Thank you for your help.
Zhen
Old Feb 11, 2016 | 05:58 PM
Is this a 4 or 6 cyl car....auto or manual trans?
Old Feb 11, 2016 | 06:54 PM
Zhen's Avatar
It is 4 cylinder, auto.
Old Feb 11, 2016 | 06:58 PM
The starter is underneath the intake manifold and difficult to see. Is the leak near a component with a pulley and driven by the serpentine belt?
Old Feb 11, 2016 | 07:45 PM
Do you mean the passenger or the driver side?
Left is driver's side.
If it is the passenger side (right), the water pump is on that side.
Old Feb 11, 2016 | 10:13 PM
Zhen's Avatar
It is on the passenger side. in front of the engine, near the battery, I am not sure it is starter or AC compressor, but it was in plain sight. The leak was under it, I could a stream of water coming from below the part, the part blocked the view. I will try to shoot a photo. it is too dark now.
Old Feb 12, 2016 | 07:44 AM
Default 2003 Coolant leak
The waterpump is right there at the belt-drive pulley, #6 in the picture.
But maybe it's the thermostat housing, #10. It bolts up to a big housing, right at the #13 label in the picture.
Old Feb 12, 2016 | 10:37 AM
Zhen's Avatar
Thanks. I marked the location of the leak in the image. It is below this major part.
Old Feb 12, 2016 | 11:12 AM
That's an F-series engine, so that cannot be a 2003 car. That's near the starter for a 1998-2002 Accord.
Old Feb 12, 2016 | 11:18 AM
Zhen's Avatar
You are right. We bought in 2003 the 2002 car. I did not realize the big difference.
I think the leak was directly below the starter but there is no tube anything. where possibly the leak comes from?
Thanks.
