2003 EX Auto Shifter Suddenly Loose
Old Feb 7, 2013 | 01:44 PM
winterland's Avatar
Default 2003 EX Auto Shifter Suddenly Loose
The transmission shifter on my 2003 Accord EX suddenly has suddenly become vague, loose even, as if it drifts between P R D D3 1 2....it no longer "stops" firmly on any position. This has not affected the transmission or the way the car drives at all, it does not jump out of gear (although it feels as if the slightest bump would make it) there is no unusual sound, the fluid it at the correct level and clean. This occurred after I had driven the car, got out, and then back in again within the hour. Any ideas? Thanks.
Approx. 96,000 miles on the clock.
Old Feb 7, 2013 | 02:30 PM
Please read the forum rules and do not post help questions in the DIY section.
I moved your thread to the General Tech Help section.
Old Feb 7, 2013 | 03:19 PM
... and I'll delete the duplicate post.
Old Feb 7, 2013 | 06:25 PM
winterland's Avatar
My apologies, thank-you both.
Old Feb 8, 2013 | 06:40 AM
I guess I should've asked whether it's a V-6 or 4-cyl? Even so I don't really know the answer.
I used to have a 98 4-cyl auto, and I thought those notches came from a spring & cam mechanism down at the base of the shift lever. Not sure if 6th-gen is the same way, but maybe you can remove some shrouds around the shift lever & have a look.
Old Feb 8, 2013 | 07:57 AM
winterland's Avatar
Thanks Jim, I'll give it a try.
Old Feb 8, 2013 | 07:58 AM
winterland's Avatar
Its a 4cyl by the way.
Old Jan 23, 2021 | 05:53 AM
Charnab7's Avatar
Default Shifter
did you ever get this fixed? This just happened to me
Old Jan 24, 2021 | 09:00 AM
Winterland hasn't posted since 2014. Unfortunately it's pretty common for us to never hear back whether something is fixed.
Anyway, is yours a 2003 4-cyl automatic, 4-door, EX?
I guess the first thing would be have a look inside the console, see if something is coming loose. Also you might check where the shift cable attaches to the transmission to see if something is coming loose down there.
tyrrvk
Feb 19, 2020 10:06 AM
Philbetterblue
Mar 10, 2017 05:16 PM
Brent E
Canada, Over Seas & Elsewhere
Jul 12, 2010 05:24 PM
kalyjor
Jan 22, 2009 10:15 PM
