2003 Honda Accord A/C blowing out warm.
The A/C on my car is blowing out warm. I added A/C refrigerant enough to fill it up a month ago.It worked for a month and all of a sudden it stopped blowing out cold. It blows our air but its warm when i have it on the correct A/C settings.The car still has all of the refrigerant I put in. Its not a leak where the air refrigerant goes and I know for sure. I think it might be a fuse that is burned out. If you have any suggestions on what the problem is or if its a fuse. It would be great to know what fuse is the one responsible for the Air Conditioner. Help Please and thank you.
1. When you turn on the A/C, does both cooling fans in the engine compartment run?
2. Check under-hood Fuse No. 12 (7.5A) to make sure the fuse for the A/C compressor clutch relay is not blown. 3. If under-hood Fuse No. 12 is okay, to do a brief test to check that the compressor runs: a. The A/C compressor clutch relay is number 2, as shown in the attached under-hood fuse/relay box diagram. https://www.hondaaccordforum.com/for...utch-relay-jpg b. You would pull that relay out, then use a jumper wire where relay terminals no. 1 and no. 2 would normally be plugged into. https://www.hondaaccordforum.com/for...king-relay-jpg Does the compressor run? Only do the test briefly. Do not leave it this way. |
