2003 honda accord v6 -camshaft position sensor location ??
Old Oct 5, 2012 | 10:17 PM
bossie's Avatar
Default 2003 honda accord v6 -camshaft position sensor location ??
hey guys im new to the forum....i wanna change my camshaft position sensor in my car....problem is locating it....can anyone help me out plzzzzz......
Old Oct 5, 2012 | 11:21 PM
Dr. Drivability's Avatar
any chance you'll tell us why?
Old Oct 15, 2012 | 05:02 PM
bossie's Avatar
Hey Thank You So Much......God Bless...
Old Oct 15, 2012 | 05:07 PM
bossie's Avatar
Default reason for trying to locate it.....
well my car was taking long to start up, and idling rough...and then would just shut down.....like after a 5 or 6 tries then it would start and it wasnt allowing me to go over 30 mph.....what i learnt was that the cam sensor controls when the injectors fire...also...has something to do with timing...well after changing mines...it starts up quite fine....
Old Sep 17, 2013 | 11:32 AM
Erveii's Avatar
Default MY 2003 HONDA ACCORD EX V6 3.0 has the some issue
can you please tell me if is this the Camshaft position sensor ??
KT132 Camshaft Position Sensor 2005 Honda Accord EX 3 0 V Tec J30A4 | eBay
i have replaced the crank sensor but seems it was not the problem so i wasted 100 usd.
Old Sep 17, 2013 | 11:38 PM
Erveii's Avatar
Default is this the same sensor
hello my friend, KT132 Camshaft Position Sensor 2005 Honda Accord EX 3 0 V Tec J30A4 | eBay any chance yo know if this is the same sensor BOSSIE was talking about ??
Old Sep 18, 2013 | 06:02 PM
Not sure about the part number in the link.......but the 03 and 05 are in the same position.
Old Mar 29, 2021 | 08:48 PM
Mrinn's Avatar
Default 2005 Honda Accord V6
I am trying to find this on a 2005 Honda accord V6, did you have any luck locating it?
Old Mar 29, 2021 | 11:17 PM
The CMP sensor is located behind the front camshaft pulley. To access or replace the sensor normally requires removal of the timing belt and front camshaft pulley.
The connector to the CMP sensor is visible without removal of the aforementioned items, and shown in this image. The connector and wiring should be checked, tests done, etc. before replacement of the sensor.
woody31
May 9, 2019 11:42 AM
Logantheswimmer
Mar 25, 2017 09:51 AM
jaxbrian
Sep 3, 2010 08:52 AM
kris_loehr
Dec 19, 2008 07:20 PM
