Cam position sensor
Old Feb 7, 2019 | 01:11 PM
woody31's Avatar
Almost A Senior Member
Default Cam position sensor
Hi everybody. I have a 1996 accord 2.2 vtec. We bought new car about 6 months ago..parked the accord. The other day I went to crank it and it just cranks and dies..code says camshaft position sensor error.. Where is cam sensor located?
Old Feb 7, 2019 | 01:53 PM
The Toecutter's Avatar
It should be in the distributor.
Old Feb 9, 2019 | 02:36 AM
woody31's Avatar
Thanks for the reply. My local Napa and Orielly Auto Parts can't find it..rock auto does not list it..i need a picture and a part number ...please and thank you.
Old Feb 10, 2019 | 09:07 PM
woody31's Avatar
Any one have a idea here...I would like to get this running again...
Old Feb 11, 2019 | 04:48 AM
Seanjordan20's Avatar
Buy a distributor. You will not find it separately because they can not be changed.
Old Feb 11, 2019 | 04:50 AM
Be sure it's not a broken belt, ignitor or icm
Old Feb 11, 2019 | 05:51 AM
woody31's Avatar
Talking
Thanks for the reply... my scanner says it is a cam sensor intermittent signal...
Old Feb 11, 2019 | 02:44 PM
If it's not in the distributor, then it's mounted down next to the crank pulley. It'll be a combined sensor, meaning 2 sensors are in the same piece of cable. The FSM shows it, but I got rid of my FSM when I sold my 97. I replaced the CKD sensor on it, but I also had to replace the other sensor since they were combined.
However the cam sensor should be in the distributor, and there's room for 1 inside since it has a divorced coil.
Old Feb 14, 2019 | 07:32 PM
The ECM cannot tell the difference between a bad sensor and bad wiring connection somewhere between the sensor & the ECM. So the scanner says intermittent signal, that may be caused by a loose pin in some plug in the wiring harness. Electrical troubleshooting is always important to show whether the sensor itself is actually bad.
Old Feb 24, 2019 | 06:20 PM
woody31's Avatar
so how do you test this 🤔🤔
