Cam position sensor
Old Feb 26, 2019 | 08:08 PM
With a multimeter, you need to check for open or short in the wiring to that sensor.
Open means there's a break in the wire somewhere, like a loose plug that sometimes makes contact, sometimes not.
A short means some wire has the insulation is worn away, or maybe it's pinched and touching something metal.
Because it's intermittent, you probably want to wiggle the wires as you're testing. I once had a wire broken inside it's insulation, so the wire LOOKED OK. As the engine moved around during driving, it would pull a bit and the wire would lose contact. Depending on the location of the problem, you repair it or replace some part of the harness.
Old Feb 27, 2019 | 02:10 PM
The Toecutter's Avatar
Yup, we found that before on my son's 98 Civic. The engine wouldn't start, due to a bad ground wire.
Old May 7, 2019 | 06:13 AM
woody31's Avatar
Almost A Senior Member
Default Cam sensor issues
My 96 accord started throwing code for cam sensor intermittent signal. I replaced the distributor. Started car and instantly same code pops up.
What am I missing? Could the vtec solenoid make this issue? I am at a loss. I tried searching for a solution but no luck. Thanks in advance.
Old May 7, 2019 | 06:18 AM
woody31's Avatar
Originally Posted by Seanjordan20
Be sure it's not a broken belt, ignitor or icm
Whatis the igniter..icm??
I replaced the distributor and same code pops up.
Old May 7, 2019 | 01:05 PM
Ignition control module ("ignitor" is slang for the ICM) is inside the distributor, so if you got a loaded distributor, then you got a new one. It's some kind of isolation amplifier so spikes from the coil don't feed back to the ECM.
Have you verified the wiring is OK for all these circuits?
Old May 7, 2019 | 01:06 PM
Flaky wiring?
Old May 7, 2019 | 01:15 PM
  #17
woody31's Avatar
How do you test for this?
I have no clue when it comes to this car.
Thanks inadvance.
Old May 7, 2019 | 02:28 PM
  #18
Seanjordan20's Avatar
There are many how to videos on YouTube. I have attached one for you so you won't be troubled on finding one.
Old May 7, 2019 | 07:09 PM
  #19
What is the actual code you are getting? They start with the letter P and have 4 numbers, like P1234.
Old May 9, 2019 | 11:42 AM
  #20
woody31's Avatar
Thanks for the help . I will check the exact code this evening when I get off work.
pondrun
Nov 8, 2021 09:40 AM
Sethgreen
Aug 4, 2011 01:58 PM
wiz929
Jul 23, 2011 06:27 PM
07AccordCp
Jun 30, 2011 04:11 PM
jazmyneaccord81
May 20, 2007 10:52 PM
