2004 Accord-Wipers Not Working *Update 8/1/06*
Old Jul 26, 2006 | 05:22 PM
cmoorevt's Avatar
Default 2004 Accord-Wipers Not Working *Update 8/1/06*
Did a search and couldn't find a similar problem...
Got in the car yesterday and turned it on. Wipers were dead. Washer fluid worked but I could not get the wipers to turn on at all, no matter what setting.
I checked the wiper fuse in the fuse box down near the clutch pedal and it was not blown.
Brought the car to the dealership who checked a few things. They bypassed the washer/wiper switch and were able to apply power to the wiper motor directly and the wipers worked so figured the problem was in the switch. They had Honda Fedex a new switch and I brought it back to the dealer this morning.
Just stopped by and it is not the switch. Apparently the switch that was Fedexed arrived damaged so they pulled one out of one of the used cars on the lot. Got it installed but the wipers would still not run. Now they think it may be a crimped wire or something similar that will take more time to diagnose.
Anything else I should suggest they look at? Its not the wiper motor, the fuse is good and apparently so is the switch.
Also, I know this is probably a case by case basis, but how much of this will Honda cover?
The vehicle has 51,500 miles and it out of warranty. At the same time, I don't think this is a normal wear and tear issue and its obviously not something I caused. The service department advisor said Honda would help with some of it, but we already have 3 hours or so of labor into this and more on the way as they are still not sure what the problem is.
I owned VWs previously with whom I had to fight for every last nickel, so maybe I'm being paranoid. Should I call American Honda directly or wait until the final bill?
Thanks.
Old Jul 26, 2006 | 06:42 PM
RTexasF's Avatar
Super Member
Default RE: 2004 Accord-Wipers Not Working
That is an odd situation and I'm sorry that I can't help you as far as the repair. Since the dealer seems to be working with you on this I would ask them about contacting Honda concerning this......should they call them or should you?
Once the repair is complete I would be very interested what the cause and the fix was, I have an '04 as well.
Old Jul 26, 2006 | 07:02 PM
No Fixy your problem, no payee the bill..Honda should foot the bill unless they find the problem..
Old Jul 26, 2006 | 07:33 PM
cmoorevt's Avatar
Thanks. I'll definitely post when they come up with the solution. Goes back in Tuesday morning.
The master technician is supposedly back from vacation next week and hopefully can figure out what is going on without spending hours wrenching around.
Old Jul 27, 2006 | 02:49 AM
deserthonda's Avatar
i am sure the shop already checked all the fuses first (or they should have ), but turn the key on, under dash fuse box,,,,,,,,chk fuses # 7 , 10 amps , fuse # 21, 7.5 amps, and fuse # 11 , 30 amps, ,,we know fuse # 20 , is ok because you said washer motor works..........
NOw My 2 cents worth on how this this was approached byt the dealer ,,,there are a lot of techs in dealerships that are terrible in electrical troubleshooting,, i worked with quite a few of them.. they DO NOT diagnose problem but rather throw parts in the hope to fix the problem,,,,,,,,Had a tech properly diagnosed the problem he ( she ) would not have replaced the switch .all he had to do is, chk for power and ground going into the switch , turn switch on and chk for power and ground on the output wiring of the switch.. if they had power and ground coming in and not going out than it would have been a bad switch,,,,it is no more than 1/2 test including removing components to ge to the switch connector
...A good tech will never guess at what the cause is and replace the part without proper diagnose .......
IT is my motto ,,and i tell all the members here and other forums i have been at ,,,,,,,before you start replacing parts,,,,,,,,,,,DIAGNOSE,, DIAGNOSE DIAGNOSE .
NOW they will charge you more money , because when a tech has an electrical problem they do not go by flat rate,, but by the time he ( she ) spend on the car ( in most cases )
YOU should not have to pay a dime for the replacement of the switch since it did not fix the problem and was totally misdiagnosed ..
problem could be a # of things ,, on such a newer car most likely loose connection, ?? they should chk all the connections and the flow of power supply in the system,, start at top and work the way down without skipping one , because the 1 they skip could be the problem 1 ..
Now they think is a crimped wire?????? they should not tell you what they think it is ( guessing ) ,... but they should come to you to tell you WHAT IT IS ..
they only got 1 guy at this dealership who can diagnose this problem ?? wow.... they should send more techs to Honda school ,,
Old Jul 27, 2006 | 11:38 AM
cmoorevt's Avatar
thanks deserthonda. I just checked those fuses and everything is fine. they also mentioned that they tested the grounds which involved something under the front bumper cover.
you're exactly right in that they seemed to be guessing which is why I was a bit worried. the service advisor said the master tech was "really good at this sh!#" so I'm hoping that is a good thing.
I wish I could figure out where all the connections were and go thru this myself cause I don't trust the clowns at the dealer. Is that a major pain or should I let them handle it?
Mechanical stuff I can do, electrical, not so much...
Old Aug 1, 2006 | 04:29 PM
cmoorevt's Avatar
Brought the car in again this morning. Turns out the problem WAS the wiper motor. This was after they told me they had 1.) tested the motor and it had worked fine, 2.) guessed that it was the switch, 3.) ordered a new switch, 4.)had the new switch arrive damaged and tried another switch from a car on the lot and 5.)spent some more time trying to solve the problem after the switches didn't solve things.
Needless to say I didn't pay a dime.
Old Aug 2, 2006 | 04:06 AM
ORIGINAL: cmoorevt
rning.
I seem to remember you saying that they gave the motor power and it worked .....if it did ,, why would they say now it was a bad motor ??? it sounds pretty shady to me ..
but the main thing is that your car is fixed and you did not have to pay
Old Aug 2, 2006 | 11:13 AM
cmoorevt's Avatar
You're right. When I first brought it in they told me they applied power directly to the motor and the wipers worked, which is why they had moved on to the switch or a crimped wire or something else as the cause of the problem. I have no idea what if they actually tested it that first day because a new motor solved the problem.
They were either lying or incompetent or a combination of the two. I avoid that dealer at all costs anyway, but this guarantees I'll never go back to them again.
Old Feb 24, 2007 | 01:24 AM
eddiefoy
I have the same model, 2004 Honda Accord, and guess what.. At about 55k miles my wipers stopped working and the fuses are good. Is this now a known issue Honda is looking into? Just wondering if I should go in and see if they will fix it or if I should work on it myself...
