2004 Honda Accord Roof Trim / Molding
I am buying a used 2004 Honda Accord EX. How can I repair the roof rubber molding? The rubber strips are coming off so the chrome is starting to show. Before I spend thousands at the dealer, what part is this? I am having a hard time finding any information. No YouTube videos on this repair at all that I can find. Also, the clear coat on the roof is gone and there are white spots. I'll have that repaired, I hope by a local Maaco not sure yet. I'm in California so, no leaks that I know of. Should I just buy something to cover it up? I saw this advertized on Amazon. Any advice would help. THanks
https://cimg9.ibsrv.net/gimg/www.hon...0b5b16110d.png |
I'm moving this to the General Tech area where more people will probably respond. The "new member" area is mostly for welcome & introductions.
Check this out (active links prohibited but you can figure it out...) www(dot)hondaautomotiveparts(dot)com/v-2004-honda-accord-sedan--ex--5-speed-automatic/interior-bumper--molding There's other on-line parts dealers for you to choose from, & most (like this one) use the Honda part numbers. The Amazon link you showed was kinda interesting - it might be a nice alternative to replacing the actual trim strip - and a lot cheaper, too. But I don't know how good it'll stick over time, and for all I know it might be just as good to use electrical tape & carefull trim with an X-acto knife. If you decide to use that, let us know if it works well. Unfortunately I screwed up & deleted your link when I meant to just disable it from being active. But it looked like it was for 1998-2002 Accord which wouldn't fit your 2004. |
The roof molding is held on with multiple retainer clips.
