2004 Honda Accord Roof Trim / Molding
Old Apr 14, 2019 | 07:17 PM
pointv's Avatar
Default 2004 Honda Accord Roof Trim / Molding
I am buying a used 2004 Honda Accord EX. How can I repair the roof rubber molding? The rubber strips are coming off so the chrome is starting to show. Before I spend thousands at the dealer, what part is this? I am having a hard time finding any information. No YouTube videos on this repair at all that I can find. Also, the clear coat on the roof is gone and there are white spots. I'll have that repaired, I hope by a local Maaco not sure yet. I'm in California so, no leaks that I know of. Should I just buy something to cover it up? I saw this advertized on Amazon. Any advice would help. THanks
Last edited by JimBlake; Apr 14, 2019 at 09:15 PM. Reason: active link to non-sponsor seller
Old Apr 14, 2019 | 09:11 PM
I'm moving this to the General Tech area where more people will probably respond. The "new member" area is mostly for welcome & introductions.
Check this out (active links prohibited but you can figure it out...)
www(dot)hondaautomotiveparts(dot)com/v-2004-honda-accord-sedan--ex--5-speed-automatic/interior-bumper--molding
There's other on-line parts dealers for you to choose from, & most (like this one) use the Honda part numbers.
The Amazon link you showed was kinda interesting - it might be a nice alternative to replacing the actual trim strip - and a lot cheaper, too. But I don't know how good it'll stick over time, and for all I know it might be just as good to use electrical tape & carefull trim with an X-acto knife. If you decide to use that, let us know if it works well.
Unfortunately I screwed up & deleted your link when I meant to just disable it from being active. But it looked like it was for 1998-2002 Accord which wouldn't fit your 2004.
Old Apr 14, 2019 | 10:38 PM
The roof molding is held on with multiple retainer clips.
glennmunis
Nov 5, 2014 04:44 PM
5Door
Mar 4, 2014 02:47 PM
neophyte
Jun 24, 2013 03:13 PM
hondamthead
Feb 12, 2013 06:54 PM
