2005 accord 4 cyl rear engine mount
Can anyone advise how to replace the rear engine mount on my 2005 accord 4 cylinder.. Thanks Wayne
Hello and welcome to HAF.
I'm going to move this to General Tech.....better place for answers. |
I have replaced rear motor mount on 94 Accord and while it was difficult, it is w/i range of most diy'rs. Your 05 Accord may be similar, but can't be sure.
I could not find any examples of a 2003-2007 Accord 4-cyl rear motor mount, so can't provide any informed guidance. Are you sure the mount is defective? I used the following procedure to inspect and locate damage in rear mount of my 94EX. 1) W/ a helper firmly set e-brake and hold foot brake. 2) W/ trans in reverse pulse the accelerator to 1500-2000 rpm. 3) Observe rear motor mount for excessive movement and damage. It should stretch but not move more than perhaps 1" under load. Reverse pulls the mount in tension and will reveal defects. good luck |
In this Acura service bulletin, page 4, it shows the location of the rear mount for the TSX. Your Accord 4 cylinder has the same K24 engine block.
http://www.heeltoeauto.com/files/pit...l_bulletin.pdf
its definitely the rear mount.. Its all ripped up..
thanks again redbull
On the 94 Accord the bracket from mount to engine must be removed also. I recollect three bolts to remove, but probabaly different here.
I found nothing on youtube about this particular accord edition. good luck |
