2005 accord 4 cyl rear engine mount
Old Feb 7, 2014 | 04:09 PM
wayne64li's Avatar
Default 2005 accord 4 cyl rear engine mount
Can anyone advise how to replace the rear engine mount on my 2005 accord 4 cylinder.. Thanks Wayne
Old Feb 7, 2014 | 05:32 PM
Hello and welcome to HAF.
I'm going to move this to General Tech.....better place for answers.
Old Feb 7, 2014 | 07:46 PM
I have replaced rear motor mount on 94 Accord and while it was difficult, it is w/i range of most diy'rs. Your 05 Accord may be similar, but can't be sure.
I could not find any examples of a 2003-2007 Accord 4-cyl rear motor mount, so can't provide any informed guidance.
Are you sure the mount is defective? I used the following procedure to inspect and locate damage in rear mount of my 94EX.
1) W/ a helper firmly set e-brake and hold foot brake.
2) W/ trans in reverse pulse the accelerator to 1500-2000 rpm.
3) Observe rear motor mount for excessive movement and damage. It should stretch but not move more than perhaps 1" under load. Reverse pulls the mount in tension and will reveal defects.
Old Feb 7, 2014 | 08:53 PM
In this Acura service bulletin, page 4, it shows the location of the rear mount for the TSX. Your Accord 4 cylinder has the same K24 engine block.
http://www.heeltoeauto.com/files/pit...l_bulletin.pdf
  1. Remove the 2 nuts that hold the rear mount stop (that piece that looks like an upside down U).
  2. Remove the 1 rear mount bolt (which runs through the center top of the engine mount) that is attached to the rear mount bracket. -- The 1 rear mount bolt is not shown in the Acura service bulletin; but, if you know how the mount looks like, you'll figure it out.
  3. Remove the 4 bolts holding the engine mount to the base.
I haven't done it personally; but, the hardest part is probably just reaching the bolts. Probably no need to jack up anything to remove, as others have said it is not difficult once you reach it.
Old Feb 9, 2014 | 07:36 PM
wayne64li's Avatar
its definitely the rear mount.. Its all ripped up..
Old Feb 9, 2014 | 07:38 PM
wayne64li's Avatar
thanks again redbull
Old Feb 10, 2014 | 07:30 AM
On the 94 Accord the bracket from mount to engine must be removed also. I recollect three bolts to remove, but probabaly different here.
I found nothing on youtube about this particular accord edition.
DonnieVanDango
Jan 3, 2014 04:08 AM
Analyzethis
Sep 6, 2013 03:47 PM
tizzo
Aug 21, 2010 08:06 PM
baer77
Feb 27, 2009 03:47 PM
ranma21
Oct 21, 2008 12:24 AM
